I attempted to jump my 2000 Dodge Neon off in the dark with a jump pack, and I accidentally reversed the polarity. The tire inflator on the jump pack landed on my positive starter wire and burned it in half. The main fuse was also blown. I have replaced both, but my fuel pump is not turning on, and I am getting no current through the starter wires when I turn the ignition. I have tested the starter, and it is working. The engine will turn over if I run a wire directly from the battery to the starter. What are some places I should start looking to fix this problem?
4You need to check all of your fuses and relays under the hood and at the main fuse block, which should be inside the passenger compartment. – Pᴀᴜʟsᴛᴇʀ2♦ Feb 7 '16 at 19:52
check for fusible links as well, I've seen these fry when a reverse jump goes bad. madelectrical.com/electricaltech/images/amp-ga36.jpg – dangel Feb 8 '16 at 0:29
Starter Solenoid
If you can turn the starter over when your skip the solenoid then I the logical next step would be to replace your solenoid.
It's a very simple procedure and the solenoid is a relatively inexpensive component
I suggest you swap out your solenoid and see if that resolves your issue.
