Ok first oil change I've ever done the plug will not come out? I used a bar cheater bar it turns and turns but will not come out. what do i do? I deliver pizza I need this vehicle. Its bad enough I got to weld the frame from rust
Car: 92 Nissan Hardbody D 21
  • 7
    Are you saying the sump plug just keeps turning? Was it very tight to start with? Are you turning it in the correct direction?
    – HandyHowie
    Feb 5, 2016 at 13:38
That seems like an unlikely scenario. You could try applying pressure against it if you can fit a screwdriver between the pan and plug while loosening.
