I have a 2000 Honda Odyssey that only drives in neutral; no reverse or forward. What do you think is wrong?
closed as too broad by DucatiKiller, cdunn, George, Pᴀᴜʟsᴛᴇʀ2, Zaid Feb 3 '16 at 14:18
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    The transmission is shot. The Odyssey was built using the same transmission used in Civic and Accord. They cannot stand up to the extra weight which the van has, so fail readily after they get a bit old. Take it to a transmission shop. I'm sure they'll tell you the same thing. – Pᴀᴜʟsᴛᴇʀ2 Feb 1 '16 at 23:29
  • @paulster2 You have obviously seen this before. Does the vehicle really drive in neutral? – HandyHowie Feb 2 '16 at 12:36
    @HandyHowie You have to give it a little push... and ideally it's sitting on a hill... but sure ;-) – Lynn Crumbling Feb 2 '16 at 17:52
  • @HandyHowie - I was wondering about that myself ... but as Lynn says, a good push will get it done, lol! (Downhill with a back wind is a good choice as well.) – Pᴀᴜʟsᴛᴇʀ2 Feb 3 '16 at 1:36
As @ᴘᴀᴜʟsᴛᴇʀ2 said, this appears to be a known issue with Honda Odyssey Model Years 1999-2001. From the Wikipedia entry for this set of model years:
The 4-speed automatic transmission in 1999 to 2001 models had serious problems with transmission durability. Honda spokesman Mike Spencer stated that four-speed models were afflicted with a bad bearing that could break apart, scattering fragments of metal that clogged fluid passageways in the transmission, causing it to shift erratically.
