2010 Jeep Patriot FD2 4x4 38,000 miles Well maintained vehicle with low mileage. Excessive vibration noticed beginning 6 months ago. Have changed spark plugs, air filter, Premium gas used with double cans of fuel injector over three tank fill ups, throttle valve inspected and cleaned with Seafoam, motor mounts and transmission mounts inspected: all without improvement. Two separate repair shops have given up on finding the cause. Car runs great on the road but has vibration in idle while at stop in Drive. Vibration worse when sitting on an incline regardless of whether in Drive or Neutral. Great car except for this issue. Have spent a lot of money chasing this with no results. What next? Compression Test, Coils replaced, ???
Vibration felt, heard and seen when in Drive at stop but disappears when shifted to Neutral [closed]
1I doubt it's a coil issue as if a coil was failing, you'd get a misfire code (most likely). You can try a compression test, it may show you something. Did they check for vacuum leaks? If so, what did they do to check for them?– Pᴀᴜʟsᴛᴇʀ2 ♦Feb 1, 2016 at 23:22
1How many RPMs is it idling at?– Lynn CrumblingFeb 2, 2016 at 17:56
What does it idle at ?– DucatiKillerFeb 12, 2016 at 8:03
Possible duplicate of Strong vibrations when idling even after replacing engine mounts (automatic transmission)– GeorgeMar 7, 2016 at 21:04
