I have a retired 2000 GMC Savanna 250 with 225/75R16 tires that have plenty of tread, no signs of dry rot, and are only 3 years old.
My newer vehicle is a 2009 Ford E350 extended, and it needs at least two new tires, these tires are older and have more wear. It is labeled for 245/75R16.
Can I put the 225 tires onto the E350 rims, would it change the safety/traction/reliability of the vehicle, and if so, how much?
It looks like the bolt patterns are the same, would using the rims and tires from the GMC change the answer?
