I have a 2005 Dodge Dakota. The left turn signal has started randomly switching over to blinking the right signal light. When it happens, the sequence is usually:
- Turn on the left signal, it blinks for a couple of times
- An out of sequence and slightly more quiet click is heard and the right signal begins flashing
Turning the signal off and then back on again gets the left signal going again.
I have confirmed that it is the entire right signal lights (not just the dash indicator). Also, all of the bulbs are working properly when the left signal is in fact flashing.
I have not had the reverse situation happen with the right signal.
