16
I just ran across the phrase "heel and toe" shifting from this answer
I've worn through the floor mat in two places trying to become better at heel and toe-ing, though.
and this question:
I've heard much and recently watched a video about performing the heel-and-toe technique.
I understand that it's to allow you to shift without the use of a clutch, but it eludes me how placing a foot on both the brake and gas pedal will cause the synchros to line up. Can someone explain the principle of what's going on?
My question is: Why does heel and toe shifting line up the synchros?
3 Answers 3
By matching the engine RPM to the revs in the gearbox, the 'synchro rings' that automatically match the gear speeds in the gearbox for you have less to do.
If you are clutchless changing all the time these wear out quickly since you are unlikely to match gear speeds well every time. When you din't the synchro rings an gears have to match the speed of the engine and clutch at the same time, normally a function of the clutch when you make a jerky change.
Worn synchro rings need to replaced - an expensive undertaking.
Bits of metal and filings from the gears also result from mismatch and may go on to cause further damage to the gearbox.
You can save a lot of wear and tear and expense on these parts by 'heel and toe'ing.
This is one of the reasons formula one cars of the past were completely rebuilt every race (Thanks @ducattikiller) . Components were used near their limits and a bad change or two by a driver often resulted in a breakdown and uncompleted race. Commonplace 20 years ago, less frequent now with new gearbox designs and rules.
Old cars that 'grate' gears when shifting down (it's more noticeable shifting down) have worn out synchro rings.
Something to watch for in purchasing second hand car - shift down after pressing the clutch in for a long time.
  • 3
    Not to nitpick but the rules since 2004 in F1 don't allow the rebuilding of engines anymore. In the current rules the engine is built and tested, then it's turned over to the FIA where it's sealed. The engine must survive 4 race weekends. If the manufacturer exceeds their engine allotment because they went through the engines then the driver must start at the back of the pack for the race where a new engine was used. Commented Jan 28, 2016 at 23:16
  • Thanks Ducatti Killer - havn't been following for the past few seasons.
    – ChrisR
    Commented Jan 29, 2016 at 6:43
15
Heel-Toe shifting and clutchless shifting are 2 different things. I guess they can be done together....
The one thing both of these techniques have in common is rev matching. There is the RPM you are at when you come out of a gear, and the RPM you will be at when you go into the next (or previous) gear. When you rev match, you try and have the engine RPM as close as possible to where it will be after you let the clutch out. This can help to reduce clutch wear and jerking when you let out the clutch.
Clutchless:
Shift gears without touching the clutch. If you are shifting up, just move the shifter, when the RPM is close enough, you should be able to slide it into the next gear. When downshifting, you need to rev the engine to match the RPM.
Heel-Toe:
The goal is to apply the brakes, and downshift with rev matching. Place the ball of your foot on the brake pedal, press in the clutch, with the right side of your foot hit the gas, shift, release the clutch. This is a lot to do all at once and takes a bit of practice. You might want to try just rev matching first so you get an idea of how much gas you need to give it. Some cars are easier to heel-toe than others and there are pedals designed for heel-toe shifting.
    When downshifting clutchless, why isn't it sufficient to just press gas? Commented Jan 27, 2016 at 20:17
    Just pressing the gas IS sufficient. Heel-toe is for when you want to brake, downshift, and rev match at the same time.
    – rpmerf
    Commented Jan 27, 2016 at 20:25
9
I'm going to expand on rpmerf's answer, where he has disambiguated between Heel and toe and clutchless shifting.
I'l briefly explain the driving technique only to better illustrate what it hopes to mechanically achieve. And so, please excuse me if get the nuance of the technique wrong.
Here's an image of a gearbox. I couldn't find a one with synchromesh, just assume that it goes where the DOG GEARS are. CONSTANT MESH GEARBOX
HEEL AND TOE - This is a driving technique for DOWNSHIFTING while BRAKING.
The point of doing this is REV-MATCHING the engine with the new transmission speed after engaging a lower gear and doesn't help the synchromesh unless you're DOUBLE CLUTCHING as well.
Technique :
  1. You press down on the brake (right foot), modulating it as per requirement
  2. You press down on the clutch (left foot) and shift to a lower gear
  3. You pivot your braking foot (toe still on the brake), such that you have your heel to press down on the accelerator (clutch is still disengaged/disconnected). You press it enough to roughly bring it to the rev's required for the lower gear.
  4. You let go of the clutch (modulate)
  5. You still continue to brake as per requirement
Mechanically - point 2 . While downshifting, let's assume that the time spent on moving the gear lever is negligible, the engine needs to pick up speed to match the rotational speed of the gear shaft, which is , for the same road speed, now higher than the previous gear. Slowly engaging the clutch would have done the same thing. By applying a commensurate throttle, you've aided this rev-matching process which was left to the clutch alone, and completed the shift in an admitidly shorter time. -
Benefits-
Faster shift - lesser time spent in between gears is good for all sorts of reasons, one of which is having consistent engine braking.
Alleviate clutch abuse - Apart from wear, you significantly reduce driveline shock that can result from quickly releasing the clutch.
Everything above apply's when you just want to shift down and don't have a need to brake. All you do is omit the braking part, and keep the rev matching part i.e clutch , rev-match and shift, release clutch.
DOUBLE CLUTCHING
This is what you want to do if -
1. you want to reduce your synchro wear
2. your synchro's are already worn 3. your vehicle doesn't have synchro's (old vehicles, and some between the 1st and 2nd gear) . No synchros on reverse gear either. but since one is stationary while engaging reverse, you're already rev-matched. Try reving in neutral and quickly engaging reverse and you'l hear a grinding noise.
By double clutching, you're trying to REV MATCH the lay shaft/neutral shaft, which on a constant mesh gear box is constantly meshed with all your gears, to the OUTPUT SHAFT , which is connected to the synchromesh and mates to the selected gear.
UPSHIFTING
  1. Press clutch
  2. Drop to neutral.
  3. Release the clutch while modulating the accelerator (reducing it, though not all the way) such that the new (lower rev) of the gearbox neutral shaft is the rev matched to the higher gear, connected to the driveshaft.
  4. Press clutch and shift to the new gear.
  5. Release clutch.
Admittedly, this process can be made faster (driving technique nuances) , taking into account that simply by lifting off the throttle you're allowing the engine rpm to fall, and hence, double clutching while lifting off the throttle and getting a hang of timing can expedite the process.
DOWNSHIFTING
If performed while braking, it'l be DOUBLE CLUTCHING WITH HEEL AND TOE. i'm only going illustrate the double clutching process.
  1. Press clutch
  2. Drop to neutral
  3. Modulate throttle - Increase rev to match the lower gear you want to shift down to . You're bringing up the neutral shaft to the RPM expected by the new gear hence doing the job of the synchro.
  4. Press clutch - so as to disconnect the engine again and have the impending shift occur without the additional engine inertia to deal with , as rev- matching can never be truly perfect.
  5. Shift gear
  6. Release clutch - Re- Engage the engine to the transmission.
Again , in practice, it's easier to blip the throttle than to hold a constant rpm when the engine is free- revving. Hence, depending on the speed of the shift, one may
  1. Blip once - at point 3. and finish the rest of the steps quicky before the engine drops in RPM .
  2. Blip twice - at point 3 and point 5 if the shift is slow . - long gear levers in trucks, or just a lazy shift.
A clutchless shift isn't commonly done on a transmission with synchro's. It can lead to premature synchro wear even if the shift feels smooth.
Clutchless shifting can be done in CONSTANT MESH GEARBOX with dog gears both up and down. It helps if the shifting mechanism is SEQUENTIAL and the rotational inertia of the transmission is low. Though, all that's another topic.
    That's next level. Awesome answer! +1 Commented Apr 20, 2016 at 17:28
