I know that steam engines are considered to be old fashioned, impractical and rarely used.
Why are they considered impractical therefore rarely used?
How exactly might a steam engine work to power a car as a replacement for the internal combustion engine?
I have made the assumption that it is possible.
    This question is awfully broad. Are you including steam turbines? If not, why not?
    – Bob Cross
    Jan 22, 2016 at 22:25
  • I didn't realise how broad it was. I hope that this edit has made it a more answerable question. Jan 22, 2016 at 22:35
  • Wrote my answer but the question changed. lol...next time. :-) Jan 23, 2016 at 7:45
  • @DucatiKiller I am so sorry about that! I was just trying to address the concerns that Bob Cross had as I thought it could get closed for being "awfully broad". Jan 23, 2016 at 8:01
    Absolutely. I like the how it worked piece, That's a nice box. I think the why we don't use them component was pretty broad though. No worries. Jan 23, 2016 at 8:09
3 Answers 3
In the early automotive days, steam-powered cars were more common than anything else.
Disadvantages of steam power for automotive use, as compared with the internal combustion engine:
  • Inefficiency. In an internal combustion engine, chemical energy is converted directly to mechanical energy in the form of expanding gas combustion products. Conversely in a steam engine, there is the extra step of transferring heat energy from combustion to superheat water, and then the expansion of the superheated water to steam to produce mechanical energy. Typically any conversion of energy from one form to another will incur energy losses.
  • Weight. External combustion and the extra energy transfer to water/steam requires extra hardware. This all adds significant weight to produce the same amount of power
  • Slow start. Even with a flash boiler, it will be necessary to wait some time for the water to be heated to the point where it can produce useful mechanical energy. In the early days of internal combustion engines, this was not much of a differentiator due to the inconvenience/danger associated with hand-cranking. However starter motors have since made this a big win for the internal combustion engine.
  • Water supply. Large amounts of water must either be carried, or there must be on-board condenser equipment to re-use water. Either way this also adds up to significant extra weight.
Despite these disadvantages, it is entirely possible for cars to be powered by steam. It is simply more economical and convenient to use an internal combustion engine.
Actually, you see, the internal combustion engine replaced the steam engine to power vehicles of all kinds. It was originally used in locomotives in the 1800s to connect the east cost of the US to the west coast. They also powered paddle wheel boats up the Mississippi and allowed for powered crossings of the Atlantic Ocean. But enough of the history lesson.
There are some inherent downfalls to using steam to power a car:
  • Startup Time - We are used to getting into a car, starting it up, and relatively quickly just going. In a steam powered vehicle, you have to warm up the boiler before you can start using it. It has to get warm enough to create steam in which will drive the engine. Depending on the model of steam engine, this could take an hour or longer to occur. There's no just jumping into the car and going to the store. There is a notable exception which was the Doble Steam Car which had a specific gas burner and small tubing which only contained a small amount of water at a give time. This allowed for the water to flash to super hot steam in short order. The start-up time on this was relatively short.
  • Big and Bulky - A steam engine usually weighed a lot. This was due to it being in two parts (water boiler & engine itself). It took a lot of metal to keep pressure contained so it could be usable. In this age of "smaller is better" format, having the bulk of a steam engine would make it obsolete before it ever got off the design canvas. You could never get the aerodynamics which are seen today on cars with internal combustion engines.
  • Dangerous - Unlike modern internal combustion engines, a steam engine was dangerous in comparison. You had a boiler which would get pressurized very high (especially considering the metallurgy of the day). This pressure is what drove the steam piston. Plus you had an external heat source (fire) which also posed dangers. If a boiler were to explode, not only would there be shrapnel from the boiler, but steam and boiling water would blow every where in a given radius, causing injury to any in the way.
  • Low Efficiency - It is stated that a steam engine only has a ~20% efficiency (not that this is too much different than a gasoline internal combustion engine).
One great thing which the steam engine had was you could produce gobs of torque with them. In the Doble Steam Car which was mentioned above, it had four pistons which powered it. With a steam engine, the piston could provide power on both the "up" and "down" strokes of the piston (this is a relative notion, as in this car the pistons lied flat to the ground). If you compare this to an internal combustion engine, you get power with each stroke of the engine, which means with the four cylinders, you'd have 16 power strokes for the four pistons over two revolutions of the crankshaft. With a gasoline 4-stroke engine, you'd only see four power strokes during the two revolutions of the crankshaft. This is a great advantage because along with the super heated steam, it provided upwards of a 1000 lb-ft of torque.
  • Interestingly, early steam engines did not use high pressure steam, but instead got most of their power from the partial vacuum formed when the steam condensed. Railway locomotives and other mobile steam engines switched to using high power steam because a given size of engine could be made much more powerful, even though failure to use the partial vacuum created by condensation degraded efficiency.
    – supercat
    Feb 14, 2016 at 7:48
The reason steam engines aren't suitable for cars is mostly due to the need for steam engines to be run at a mostly consistent minimum speed, and they don't adjust speed very well.
Steam engine do not need to be inefficient, but they do work best when under constant use.
