Is the engine made by Peugeot or Ford? Apparently if it's Peugeot, it could be prone to the turbo failing due to engine fault.
If I recall correctly, the engine was designed by Peugeot/Citroen (PSA) but made by Ford in Ford’s London factory.
see https://en.wikipedia.org/wiki/PSA_HDi_engine and https://en.wikipedia.org/wiki/Ford_Duratorq_engine and
    Wiki suggests half made at ford factories, half at psa. But doesn't say I the TDCi ones are always made at ford. Jan 22, 2016 at 19:05
    Ian, could you edit the answer to include the relevant parts of the wiki into the answer? Thanks
    – Zaid
    Jan 22, 2016 at 19:06
    @Zaid, wiki does not have any solid information on the answer, just background. Hopefully someone else will have a better source of information that has more details. Jan 22, 2016 at 19:18
  • Would be good to know, if I'd known it was a Peugeot engine I wouldn't have bought it. Jan 23, 2016 at 9:27
