when I hook my scanner up to view the check engine codes it says I have no power to my scanner. I tested all circuits and my fuses are all good. what could be my problem?
    Welcome to the site. Please confirm that you trying to read codes with the ignition in the 'On' position. – Zaid Jan 18 '16 at 18:13
    Also confirm you are attempting to utilize an OBD-I scanner and not an OBD-II scanner. – Pᴀᴜʟsᴛᴇʀ2 Jan 18 '16 at 18:28
  • OBD 1 did not provide power to the scan tool. Commonly there is an external cable that hooks to the cigarette liter. – vini_i Jan 18 '16 at 21:34
  • @vini_i - Hadn't thought of that ... my Innova scanner doesn't require an external power source ... guess it must run off of batteries inside the unit. – Pᴀᴜʟsᴛᴇʀ2 Jan 19 '16 at 2:46
  • Alternately, you can jump 2 pins on the DLC connector and the CEL will flash the codes. Instructions here: chevytalk.org/fusionbb/showtopic.php?tid/273660 – rpmerf Jan 20 '16 at 17:22
