please help Changed clutch and slave cylinder Trying to bleed it but just air bubbles Can't see any leaks It's a 2004 Camry Could it be the booster ?
    Did you actually change the clutch, or the master/slave for the clutch? Also, did you bench bleed your hydraulics prior to putting it on the car? I don't think there is a clutch master booster (like a brake system; I've never seen one) so I doubt that is at issue. – Pᴀᴜʟsᴛᴇʀ2 Jan 17 '16 at 21:35
