I have a 1995 VW Jetta GL, 2.0 engine, 5 speed, a/c.
My heater won't switch between defrost, floor heat or vents. It's stuck on the vents and I can't seem to find out why.
- I have torn apart the interior panel and disconnected the cables and worked them manually (no help).
- Everything gets hot and cold and the fan motor works great but it's all just stuck on blowing the air out of the vents.
- When I switch it to defrost, the air from the vents slows down a little but not enough to defrost the front window.
What could cause this?
Please help; it's taking forever to defrost my car in these cold mornings.
