According to TireRack.com, your standard tire size is 195/65/15. This tire has a rotation per mile (RPM) of 832. The Michelin tire has an RPM of 836. This is only a difference of ~.5%, which is not a big deal. Using the two different tire sizes shouldn't cause you any issues.
The major concerns here is to keep the same size tires on the same axle (front or back). If you put different size tires on each side, it could cause instability issues.
The concern I had with anti-lock brakes (ABS) is if there is too much of a difference in sizes, it will drive the ABS and/or stability program crazy, shutting both down and making that function useless to you. This would, of course, cause a safety concern for you which I assume you were trying to avoid in the first place.
