I have a 98 Toyota privia and upon starting it the starter just keeps going. This only occurs in drive and neutral. The vehicle also starts in any gear. When I start in park the starter keeps spinning until I shift then it stops: same as neutral. Also if I nudge the shifter arm on the transaxle it stops.
I've already put in shims with no effect.
