Form the past days my car is having an issue when I turn the steering wheel (left to right) at the start point.and the same sound (grinding type) dissapear while I am on the continuous run.just a week ago I have replaced the new alloy wheel and tyre of car, from then to now I am getting the same sound.
one more thing the earlier alloy wheel was 16 in and the new one which I replaced is 17 inch with the tyre. does it matters to the steering wheel sound..?
Please suggest.
  • Did you change all 4 wheels from 16 to 17 inch? If not, which wheel did you change?
    – HandyHowie
    Jan 11, 2016 at 13:05
  • All 4 wheel changed from 16 to 17 inch.
    – user14205
    Jan 11, 2016 at 13:21
  • Is your power steering fluid reservoir topped up with fluid?
    – HandyHowie
    Jan 11, 2016 at 13:28
  • yes. two days ago fluid is topped up.
    – user14205
    Jan 11, 2016 at 13:33
  • yes.fluid is topped up 2 days ago
    – user14205
    Jan 11, 2016 at 13:36
Your rubber is grinding against the front wheel well liner - there is a plastic area there your tire grinds against on full lock because you upsized your wheels.
Solution - take a heat gun and warm up the area where the tire grinds, then push it out a bit. Don't overheat as it easily melts.
Here: enter image description here
