Good day. I've just done an engine overhaul of a Fiat Palio 16. When I try to start it the is swing but not start.
1What do you hear when you try to start the engine? – HandyHowie Jan 8 '16 at 12:15
1Tell us what parts of the engine you have changed/adjusted. – HandyHowie Jan 8 '16 at 12:16
1The very basic needs of your engine are spark, fuel, and pretty importantly air flow. Although it might at least kick over once if air flow is restricted. Have you tested for spark and proper fuel pressure / fuel in the carb bowl? (I have no idea if a Fiat Palio 16 is fuel injected or carburated,) How old is this car btw? – cdunn Jan 8 '16 at 12:53
2Welcome to stack exchange and thanks for your contribution. You can click on this link and take the tour to see how the site works. mechanics.stackexchange.com/tour Thanks for contributing with your question. We'll need some additional information to answer your question. As much information you can add to your question will help us to answer it. Again, welcome to SE. Cheers! – DucatiKiller Jan 8 '16 at 13:47
By "is swing", do you mean the engine rotates freely when the starter is engaged? – kmarsh Jan 8 '16 at 14:21
