Car: 2003 Honda Civic Si G1Wh dash cam, 400w amp, 4300k HIDs
My alternator failed badly (stereo cutting off), no battery light. Replaced it with a reman Duralast, battery light is on. It shows 14.5v while running, and I've had the battery tested at 2 different stores, both good. The car has only died once in 3 months (I leave my dash cam on overnight sometimes). The car has an electrical load detector, but there is no CEL indicating a problem with it. Fuses good, grounds good, alternator connection good. Cruise control doesn't work, and just threw a TPS code, not sure if that's related. What gives?
