Some people say that when choosing jack stands/wheel chocks, we should always leave plenty of room above the vehicle weight. For example, if the car is 1.5 tons, we should choose jack stands with a 2.5 tons weight capacity in the specification.
My SUV has a weight of 5000 pounds, which is 2.5 tons. So what jack stands/wheel chocks should I choose? Are jack stands with 3 tons capacity enough?
    Keep in mind that each stand will only have 1/4-1/3 of the weight of the car on it if you're using it near the wheels.
    – JPhi1618
    Jan 6, 2016 at 19:30
  • 3
    Get the best ones you can afford above your weight capacity. You can never have enough, but too little will kill you. Jan 6, 2016 at 19:32
    @Paulster2 Since I'm a safety nut I love that you put in the threat to life and limb at it's most extreme. When viewed from that perspective is it a good idea to skimp on a good jack stand? Jan 6, 2016 at 19:51
  • @DucatiKiller - While I believe that your question is rhetorical - I'll still answer it in a word: Never. Jan 6, 2016 at 21:23
For most situations if you're putting the SUV up on 4 stands @JPhi1618 is correct, only 1/3 to 1/4 of the vehicles weight is sitting on each stand. I have put a Toyota Sequoia on 3 ton stands and they are steady as a rock. The Sequoia has a curb weight of up to 6,000 pounds. At that I was still no where near the rating for each stand. Even putting just the front or rear on stands (with both wheels on the other end tightly chocked) the end on the tires is still holding roughly half the weight of the SUV.
Two 3 ton stands holding up the front end of a 6000 pound curb weight SUV will more than do the job since each is only holding at most 2000 pounds. (front end is heavier, so call it 4000 pounds front, 2000 rear, and there are two in the front, so 2000 pounds each).
In the end, buy the biggest, best, highest rated jack stands you can possibly afford and then treat them like gold. Don't let them get rusty, etc. Literally your life depends on them doing their job.
One thing to be careful about is the height to which the jack stand will rise. The Sequoia has a very high ground clearance so the jack points are also high off the ground. Be sure you get jack stands that are stable when extended high enough to give you room to work. That might be harder to find. I have often used ramps backed up by jack stands (drive up on the ramps, put the stands in place but not 100% extended in case the ramps failed) to give enough room. Just make sure the ramps will handle 3 tons as well.
Also be sure of the jack stands footing. The wrong kind of stand might sink into your driveway on a hot summer day.
Hope that helps!
  • I would read the information that comes with the stands. The couple of pairs of jack stands that I have had all say something similar to, "This pair of jack stands is rated for 3 tons." That means that each one is only rated for half of the load printed on the packaging. It may be different if you are buying a pair versus single ones, but mostly the stands are sold in pairs. Just a point to be aware of.
    – hazzey
    May 14, 2016 at 1:04
