2005 Hyundai Elantra. Says its running hot but has coolant and so far hasn't over heated and also can't turn on heat in car because smoke pours from vents into the inside of car.
    Are you sure it's smoke, could it be antifreeze steam?
    – vini_i
    Dec 28, 2015 at 13:29
  • does smoke come from the vents when the temperature is set to cool? If not your heater core is likely bad. This can cause coolant loss and air bubbles in the coolant system.
    – rpmerf
    Dec 28, 2015 at 13:45
  • Is there any water/coolant on the floor of your passenger side within the vehicle? Dec 28, 2015 at 17:25
  • Voting to close, question is too broad (undefined) and OP hasn't responded to comments.
    – dlu
    Oct 30, 2016 at 21:29
