7
I have an FI light on my Kawasaki motorcycle that is 2002 or newer.
How do I get the error codes so I can troubleshoot it?
7
How do I pull error codes from my Kawasaki motorcycle?
Here are the instructions to pull error codes from your 2001 or later Kawasaki street motorcycle.
Step 1
Pull off your seat and near the battery negative terminal there will be a self diagnosis lead coming out of a connector. The wire is yellow. It looks like this.
enter image description here Step 2 Get a wire, one with alligator clips on either side is what I use. Makes things a bit easier.
Attach the alligator clip to the yellow wire
Step 3 Turn the ignition switch to the 'ON' position and wait a few seconds for the start procedure to complete.
Step 4 Attach the lead to the batter negative (ground)
Step 5 Watch your FI light. It will begin to blink long and short flashes.
Step 6 You will now interpret the flashes into a numerical value using the following table.
Interpreting Error Codes The FI light will be flashing long and short blinks.
The long blinks represent 10 through 90.
The short blinks represent 1-9
If you get three long flashes followed by 4 short the error code would 34 and you can reference on the table.
Kawasaki Dirt Bikes
This technique does not apply to Kawasaki dirt bikes.
If you have additional information regarding Kawasaki error codes in various dealer modes, please please message and provide links and I will add it to this post.
Images pulled from ocmoto.com
