When I turn on ac after a while a mist starts coming out and I have a leak under dash 💨 for about a month now.
What can it be?
Please help
A blocked drain pipe below the A/C evaporator in the passenger compartment would cause this. Directly beneath the dash underneath the car you will probably find a couple of open-ended pipes that are meant to drain condensation from the A/C system. These are probably blocked so the condensation is building up and leaking into the passenger compartment. Use a drinking straw or something similar to poke the pipes clear, don't use anything sharp or hard that could damage the A/C internals.
  • Often accompanied by a "running water" sound or "sloshing water when turning"...
    – JPhi1618
    Dec 18 '15 at 17:35
  • I agree with your analysis, but would suggest using a long thin wire to get the drain unblocked. The distance from the opening to the blockage can sometimes be a bit. Also, something stiff is going to work much better than something which will flex. Dec 19 '15 at 2:38
