I just bought a Mazda Protégé 2002 and a few weeks later I noticed a damp spot on the back passenger side floor. Very wet and soaked. Later I noticed the smell grew larger and the vapor on the glass grew heavier. I then noticed the water was also in the front passenger side. I used a vacuum and soaked about a cup of dirty "water" can't tell if it's water or a leak from within.
Any ideas on removing this water, if it was because of the rain? Or where to look if the liquid came from a leak from within the car?
Edit: also the water reaches to the trunk and all areas is just the right side, passenger side
  • Is the water there even with the AC off?
    – Zaid
    Dec 14, 2015 at 21:14
  • I haven't used the AC once yet. I've only turned the fan on but only to dry the water that has already been there
    – ErickES7
    Dec 14, 2015 at 21:21
  • In that case it would confirm my suspicions of a leaking evaporator. Check your radiator fluid level; I think you're losing coolant
    – Zaid
    Dec 14, 2015 at 21:24
  • Does the fluid smell a bit sweet? That's a tell tale sign thit @Zaid is onto something regarding your issue. Dec 14, 2015 at 21:35
Certainly sounds like the heater core is leaking coolant into the car's interior. Like Ducatikiller said it should smell a little bit sweet, but if you still can't tell stick your finger in the fluid and give it a rub-test. You will be able to tell water from engine coolant by how it feels. Also have a good look at the floorboards and the firewall in the front passenger seat area. The heater core is a very small "radiator" which is mounted in the car's heater assembly, engine coolant circulates through this radiator and the heater fan motor blows or sucks air through this radiator to provide hot air inside the car. When the heater core leaks, most of the time the engine coolant leaks inside the car. And it will stay on the right side due to the usual shape of the floorpan.
  • Yes, you're right on the money. Not sure why I was calling it the "evaporator" in my comments, lol
    – Zaid
    Dec 15, 2015 at 6:57
  • Gonna give this a try :)
    – ErickES7
    Dec 15, 2015 at 19:41
After removing the seat and looking underneath the carpet, there was no evidence of leaking from the heater core. It was rain water, about three gallons of it. Where did this all come from? Nothing from the doors, windows, or underneath the frame of the car.
All of this water came from two sheets of metal joining behind the back of passenger brake light. There was a small, small gap between the metal which allowed nearly all the drain water that flowed to the back of the car to leak inside.
brake light leak a closer look
From then on I was convinced water would overflow and pour from the back to the front of the car from this single leak. I then had to remove the bumper frame to apply this water proof coating over the crack:
coating
Nothing has entered the car ever since but in case water did make inside I removed a plug from each side of the trunk where the water would build up:
removed drain plugs
A sneaky way to leak into the car it surely was :)
  • Thank you everyone for your replies and answers. By the looks of it your answers helped many :)
    – ErickES7
    Dec 31, 2015 at 20:26
