I want to calculate the battery life of a car based upon OBD2 parameters like engine load, distance traveled, Control Module voltage etc.
Can anyone please guide me as to how to do this?
If possible, at least the time taken for discharging the battery
  • What class and series will this vehicle be entered into? What's the make/model/year of the vehicle? Dec 11, 2015 at 17:45
You will not be able to achieve this using OBDII for several reasons:
  • The battery is charging while the engine is running, so monitoring battery voltage in this state will give a false impression
  • Battery health is assessed while it is not being charged and under load. Unless there is a heavy electrical load like headlights, the battery will not be under sufficient load to do this with the engine off
    Don't forget that every vehicle would be different, too. Too my way of thinking there just about zero chance of an OBDII system being a able to do this, with or without the vehicle being running. Dec 11, 2015 at 12:12
    Slow update speeds are also going to kill any hopes of instantaneous measurements like trying to check the voltage while starting.
    – JPhi1618
    Dec 11, 2015 at 15:02
  • Good points @Zaid Dec 11, 2015 at 17:46
