Hi I own Renault Megane Mk3 for while and car's paint is almost full with small scratches due to hard cleaning( car was cleaned by a hard surface ), I know its stupid thing to make but it wasn't my fault. So is there is way to fix this? Rather than repainting the whole car because its quite expensive in my country.
You will get how scratches look like in photos.
Those circles that appears when a light reflect on car's surface. If photos are not clear I'll provide another photos
  • It's actually not that difficult to paint the car yourself: amzn.com/1932494227 Dec 3, 2015 at 8:42
  • i don't think I'm going to do this right, because I have no experience in car painting Dec 3, 2015 at 8:45
  • The book is written for people with no experience. It also covers how to buff out old superficially scratched up paint and touch it up. Dec 3, 2015 at 12:34
    @RobertS.Barnes, Heh, painting a car has to be one of the hardest DIY things you can possibly do. Paint restoration maybe, but a full paint job at home is a pretty silly suggestion for 99% of people out there.
    – JPhi1618
    Dec 3, 2015 at 19:53
If the car is covered in superficial scratches then a good polishing job will work wonders. Take it to a reputable shop and behold how sexy you car has become. You can do it yourself if you have a polishing machine, it will be a huge chore without it.
Note that it won't help against deeper scratches, it is hard to tell from the photo how deep they are in your case. In the case of deep scratches there are kits for reducing their visibility, but are usually oriented towards single deep paint cuts. Many shops do it as well, but don't expect miracles if it is done without part repainting.
  • The scratches aren't deep they look like scratches on mobile phone screen. Dec 3, 2015 at 9:14
  • In the case of light scratches a proper polishing job should restore the finish. Dec 3, 2015 at 9:38
  • Polish did not remove the scratches completely, I can sill see the scratches under light Dec 5, 2015 at 9:40
    Either the scratches are too deep or the polishing job was poorly/improperly executed. Either way, more polishing should yield increasingly better results. Dec 7, 2015 at 12:43
