I was on my way to work and car started to run rough stumble and check engine light started to flash. Immediately turned around limped home about 3 miles. Changed plugs and swapped some old coils around. Still idles low and strong gas smell from exhaust. Any ideas need my car for work.
2Welcome to the site. We need more information. Can you plug in a scan tool and see if there are any codes?– ZaidNov 30, 2015 at 6:41
1Also, after you get the codes, check the fuel pressure at the rail and tell us the reading.– Pᴀᴜʟsᴛᴇʀ2 ♦Nov 30, 2015 at 12:16
No i dont have a scan tool or fuel pressure gauge.I know the car is running lean.strong gas smell out the pipes.im getting at a minute of air releasing after i shut it off.sounds like passenger side up near radiator.4th and 5th gear it will bog and cough.any help.appreciated.– Kevin HaightNov 30, 2015 at 17:15
Swapping coils and changing plugs will not make a quick fix. You need to plug in a scan tool and retrieve data. There are over 1000 reasons that check engine light can come on. Thats why diagnostics are important. If you take it to a parts store they will usually scan it for you.– cloudnyn3Nov 30, 2015 at 21:39
I dont know its a good idea to drive it.when i tested it from plug change it bogged worse as i went.a couple blocks.any ideas at all.– Kevin HaightNov 30, 2015 at 23:14
I believe you have a bad Engine Coolant Temperature Sensor (ECT in Ford nomenclature). The code P0116,the smell of gas, and the rough idle are all symptoms of a bad ECT. Its Ford's part number F5AF-12A648-AA. Get the OEM part. Its about $25. Be careful replacing it because your car has a plastic intake manifold that tends to break.
I also changed the ect sensor the crank sensor the cam sensor and the egr.now i get po116 and the po304.could a dirty cold air intake filter cause the misfire in #4 and the 116 code which is misfire detected in first 1000 reolutions after start up. Jan 10, 2016 at 0:58
Based on the codes, I'd say race fever's spot on:
P0300 - Random/Multiple Cylinder Misfire Detected
P0116 - Engine Coolant Temperature (ECT) Circuit Range/Performance Problem
P0304 - Cylinder #4 Misfire Detected
P0174 - System Too Lean (Bank 2)
Explanation
I believe what's happening is the coolant temperature sensor is giving no signal or a signal that's out of the normal range (P0116).
Under such circumstances, it wouldn't surprise me if the ECU assumes a default temperature which is an under-prediction when the temperature is warm (engine running rich, smell of fuel in the exhaust) and an over-prediction when the temperature is cold (resulting in the misfire codes).
The fix
I don't know if the ECT sensor is a common issue on this Mustang. Before you buy a new sensor, make sure that the sensor signal is getting picked up by the ECU using a scan tool.
If you obtain no signal or a constant temperature readout via a scan tool while the engine is warming up, this would indicate a loose connection or bad sensor.
Hope this helps.
^ This is best answer. Mark it as the correct one when the time comes. Jan 1, 2016 at 20:29
