I have a 2002 Chevy Venture, that supposedly the Mechanic changed the spark plugs, but when trying to do a tune-up one of the Spark Plugs broke off and the electrode is still in it. I found online a lot of Spark Plug extractors for Fords, but, none for Chevy.
I was wondering, how can I remove the electrode?
after that I know I can use a Extractor to remove the rest.
Thanks in Advance.
closed as too broad by Zaid, DucatiKiller, Pᴀᴜʟsᴛᴇʀ2, Poisson Fish, vini_i Dec 18 '15 at 0:51
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • 5
    Please post a picture of what you have already removed. I've run across this issue many times, but depending on where it broke off makes a HUGE difference in how difficult it is to remove it. – cloudnyn3 Nov 23 '15 at 3:58
    Possible duplicate of Broken spark plug – Chenmunka Nov 23 '15 at 10:34
    I'm voting to leave this open for two reasons: 1) the original question (linked by Chenmunka) did not have a selected "answer"; 2) This situation is probably different than that question. – Pᴀᴜʟsᴛᴇʀ2 Nov 23 '15 at 16:39
  • Without a picture, this question is going to be hard to answer – Zaid Dec 16 '15 at 7:59
