Are 6L90 transmissions interchangable between the different types of vehicles that GM puts them in? Example: Camaro and Silverado 2500HD
There may be interchange between the 2WD truck version and the Camaro version, but the case is physically different when you look at the 4WD truck version. Also, there are only two cars which use the 6L90: Camaro ZL1; Cadillac CTS-V. Every other application is in a truck/van of some sort. You won't just find them laying around out of a car is what I'm getting at.– Pᴀᴜʟsᴛᴇʀ2 ♦Nov 20, 2015 at 12:18
@Paulster2 : Any reason why this is a comment and not an answer?– ZaidDec 12, 2015 at 19:51
1 Answer
