I've got my motorcycle up in the air about to pull the frame up off the engine but I need to remove one last thing. I got everything taken apart except this center bolt holding the front forks on. How do I get this bolt out or how do I get the front forks off 2012 YAMAHA R6
You will require the appropriate spanner wrench to remove the primary bolt and the locking bolt.
Here is an image
Once you have removed the bolts you will be able to remove the top plate of the triple tree and the bottom portion will stay attached to the forks.
Best of luck.
