The engine was misfiring for quite a while. At some point, the battery went dead due to a bad alternator and all the electrical systems went nuts. I replaced the alternator & battery. At some point, I got a po303 diag. code. I changed plugs & wires the code went away. The misfiring seemed to go away. A day or 2 later the po303 code returned after a 100 mile drive. I pulled #3 plug & wire & reinstalled them. The code went away. It seemed to run better for a while. Then it started misfiring again. A few days later, it showed a po420 code. A few days later while researching for a repair to fix the po420 code, the code disappeared. A few days later It got a po306 code. Misfires in #3 then in #6 suggested a bad coil tower & I replaced it. It seemed to run great. A day or so later, it started to misfire again. At this point the misfire seems worse after first starting the vehicle. At one point today, when we sat at a traffic light in gear it missed. Putting it in neutral or parks, cleared the misfire. After parking for 30 minutes, it misfires both in gear or out of gear. Any suggestions would be helpful.
    Have you checked underhood at night for any signs of electrical leakage? Also, you may try changing out different pieces (like the coil towers) to see if the problem follows. I know you said you put a new coil in that spot, but I've seem before where you'll get a bad replacement part. Nov 13, 2015 at 21:38
3 Answers 3
Sounds like a bad ECM (engine control module, AKA the computer). Its a common issue with your vehicle.
Edit:
A bad ECM will throw inconsistent error codes. Have a mechanic test with another ECM before you set off and replace other items.
    Your question popped up into the edit cue as low quality. This is an automated process that does the ID'ing so no one is being judgy. Wondering if you can add some explanation and body to the response and anything that you can provide that will support the claim, any additional facts to support what you are saying. Thanks again and glad to have you around knocking out questions! I'll leave this alone and won't delete so you can uplevel it if you want. Dec 15, 2015 at 0:27
    Couldn't agree more with @DucatiKiller - Just like the other answer I commented on, please give your answers some meat so they don't get closed arbitrarily. You are more than likely spot on ... just give us some reasons to upvote your answers! Dec 15, 2015 at 0:43
  • I'd like to add that PCM replacement is non trivial and requires the dealer or a mechanic that can rewrite the VIN to the PCM.
    – Ben
    Feb 13, 2016 at 4:21
Sounds like an electrical leakage. If the cables will reach, put cables 3+6 on 1,2,4 or 5 and see if the misfire persists on 3/6. if it does, check the coils.
The p0420 code refers to a low catalyst threshold. If your misfire isn't due to a leakage, you might have a bad catalytic converter.
Since multiple parts were already replaced I'd be looking at the signal from the crank sensor to the PCM (brown/light blue). As well as signal from PCM to coil 3 (brown/orange) 5v square wave. IIRC coil 3 is the 3/6 pack, this should be a 12v square wave.
Don't forget about the fuel system either. You should test fuel pressure and injector signal/injector function.
You should also make sure the engine is mechanically sound, do a compression test, check engine vacuum etc...
