I have a Hyundai Tucson , 2008 model.
About 20 months ago while my wife was driving the car, some smoke come out and she stopped the car and they tow it. (She doesn't remember white or black smoke)
After that in about 6 months car started to studder while I am driving. It was skipping a beat. I take the car to mechanic and change the spark plugs. One of the plugs was really wear out.
Next time, probably in 4 months after that same problem. This time I change plugs plus the ignition coil. Problem solved and come back after 3 months.
I have been changing plugs regularly so that I can use the car. I suspect at some point of time car overheated and engine block got damaged and there is water in the engine as a result and that is the root cause of all studder problems. Do you guys agree?
I will throw the car away in another 20 months. (Where I live cars are expensive and you get to use them only for 10 years). Shall I get it properly fixed or just keep changing the spark plugs and use it until the license expires?
  • Do you have an old plug that you could take a photo of and put on here? – HandyHowie Nov 7 '15 at 12:35
  • @HandyHowie sadly no. But I will take picture next time. – TGG Nov 8 '15 at 1:07
  • how many miles are on the car? – Alex Volpe Nov 14 '15 at 18:10
  • @AlexVolpe 170k kms. – TGG Nov 18 '15 at 5:58
I don't agree with your diagnosis. You could have a faulty injector which is causing the cylinder with the problem to run lean. This could cause the plug to overheat and wear out quickly. Was the plug clean and shiny, not black?
Seems like it is more likely running rich, could still be an injector problem.
  • One of the plugs was dark. Others were better looking. It seems one of the plugs wears out faster. Which made me believe engine has water inside which cause the wear. – TGG Nov 7 '15 at 11:05
  • Was it beyond cleaning and reusing? What you are describing sounds like the cylinder is running rich, not lean, which is the opposite of what I thought. It could still be the injector thought. Usually running rich does not ruin the plugs, they would just need cleaning. – HandyHowie Nov 7 '15 at 11:08
  • It was beyond cleaning. – TGG Nov 7 '15 at 11:09
  • We're the electrodes worn down? – HandyHowie Nov 7 '15 at 11:30
  • yes electrodes seem to be gone. – TGG Nov 8 '15 at 1:07
