Recently replaced airbags in a fiat 500 1.2L (2010 model). I've also cleared the crash codes/data from ECU.
I assume I would have to replace the front crash sensor as well, but couldn't locate it. The following link (although a different year and engine size) suggests it's under the front slam panel.
http://www.fiatonlineparts.com/a/Fiat__50014L-I4-MultiAir-Turbo--6-Spd-Aisin-F21-250-HD-Auto-TransL-TREKKING/61624596__6591792/Module--Impact-Sensors--Air-Bag/i2322911.html
Is there anywhere else it might be or are there any tips on how to locate it?
Also I found this link which seems to suggest there is a sensor underneath the steering column. Would this also need replacing?
http://www.fiatonlineparts.com/a/Fiat__50014L-I4-MultiAir-Turbo--6-Spd-Aisin-F21-250-HD-Auto-TransL-TREKKING/61624596__6549443/Air-Bags-Modules---Impact-Sensors-and-Clock-Spring/i2323680.html
So my main question is, do I need to replace the crash sensor and if so where would it be on the particular model I'm working on?
Thanks in advance.
  • Having the same problem did you figure it out – Keir Jul 11 '17 at 17:36
