Can anyone help just got home and have gone to do my electric windows up and non of them will go up I had an issue with the passenger side switch not doing the window up but would do it down but now non work at all and my windows are stuck down
  • 5
    Have you checked the fuses for the windows?
    – JPhi1618
    Oct 19, 2015 at 16:07
  • What type of Ford do you have (year/model)? Oct 19, 2015 at 20:29
    Possible duplicate of Electric Windows won't go up
    – Chenmunka
    Oct 20, 2015 at 10:50
  • @Chenmunka - The one you listed is the one which was closed as a duplicate of this question. We should be nice and leave this one open. Oct 21, 2015 at 0:42
  • If all of them suddenly stopped working then definitely check the fuse. Oct 22, 2015 at 8:13
I have experience this problem myself. After I bypass the switch by unplugging it and finding the hot up and hot down wires at the switch and make sure the windows do in fact go up and down, then I know it is the switch. Sometimes the contacts inside the switch get dirty and wont put the current through to the windows. I have removed the window switches and soaked them in purified water for an hour or so then blown them out with compressed air, spray some WD-40 in them and give that a try. If that doesnt work. Buy a new switch, or once you know it's the switch, buy a new switch and forget it
