I got brand new tires in April. In July they started growing unsightly brown stains. Even after I wash them the stains reappear within hours. Kind of annoyed because they were hella expensive and they are really unattractive.
So 3 questions:
  • why?
  • is it possible to get rid of them?
  • is this something I could take up with the manufacturer to get them replaced?
  • Have you tried tire dressing? – Pᴀᴜʟsᴛᴇʀ2 Oct 15 '15 at 2:26
    @Paulster2 I haven't, I really don't like the shiny used-car-sales-lot look they give. – purpleACR Oct 15 '15 at 2:36
  • I would take them back, for all you know, the rubber could be deteriorating. The tire company are the ones most likely to have seen it before. – HandyHowie Oct 15 '15 at 7:14
In my specific case, I called the distributor (Tire Rack - not sure if mentioning them is allowed, but it's a positive experience and I'm not affiliated)
They saw that the brown stain was in the same pattern on every tire and "deduced" that it was something on the tire, not a problem with the tire itself. They recommended using "Goof Off" to spray on the tires. I got the "Heavy Duty Spray" strength, mentioning this because there were about 20 strengths to choose from. I actually couldn't find it at an auto parts store as it's more of a home improvement item.
I tested on a small section and it seems like the brown has finally permanently been removed. It's been black for 2 days and actually the rest of the tire which was "black" before looks brownish by comparison. I plan to apply it to all 4 tires and will follow up if this changes.
This sounds like tire blooming.
Why
Tire rubber usually contain an anti-ozonant which prevents UV damage to the tire (like you might see on a windshield wiper blade, it starts cracking). The anti-ozonant, when exposed to air, turns brown. Since the anti-ozonant is part of the tire's rubber, it continues to rise to the surface of the tire.
Usually you want to use a gentle cleaner. Using something too harsh may result in exposing more the the anti-ozonant to the air. Once it's cleaned off, dress the tire in a protectant.
Perhaps. If it is tire blooming then might tell you its completely normal and expected. It might be the result of a manufacturing issue, returning "within hours" is a bit unusual, I would at least make an inquiry to the manufacturer.
  • Thanks. I've called the distributor and will follow up with their response. Not even hours, they show up again in less than an hour. Also I'd understand if they were a $400 set, or 2 years old or something. But a $1500 set after just 4 months is unacceptable to me! – purpleACR Oct 16 '15 at 0:17
    Well this is embarrassing, it seems like it was just some grease on the tire. In my defense I did wash them repeatedly, but with the right product it seems to be coming off permanently. – purpleACR Oct 19 '15 at 16:44
  • Good thing you called and asked! – vcsjones Oct 19 '15 at 20:06
You said you don't want that really glossy look for your tire, perhaps a low gloss tire protectant spray might be the best alternative to help your tire bloom issue if you are unable to otherwise fix the issue with simple cleanings.
