It will start, idle, rev up to 6,000 RPM in park or neutral but as soon as you put it in gear and step on the accelerator it dies or chugs ? PS: Limp mode does the same !
closed as too broad by DucatiKiller, Fred Wilson, George, Nick C, Rory Alsop Jan 4 '16 at 12:16
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • Which fuel does it use? – HandyHowie Oct 7 '15 at 19:28
  • High octane/High test gasoline...just had the shop replace the in tank fuel pump...didn't help ? – user12571 Oct 9 '15 at 5:49
  • I don't know if you even put a timing light on this computer controlled timing....I did, and it seems to retard when revved instead of advance ??? – user12571 Oct 9 '15 at 5:51
  • I would start by checking the crank/cam position sensors. – HandyHowie Oct 9 '15 at 7:33
  • @user12571 Have you resolved the issue or do you still have it? – DucatiKiller Dec 26 '15 at 21:44
