I've recently bought a 2005 Skoda Octavia (in Europe, if that matters) and I could use some help with pinpointing a source of a windlike whistling noise comming from the rear left door.
The door has a double seal (inner and outer) and a standard single glass seal. The whistling noise comes from the very rear of the door but I find it impossible to pinpoint the exact source. The noise is directly proportional to speed and nothing else seems to have an effect on it. The noise is bearable up to around 80 - 100 kph but at higher speeds it becomes very loud and no reasonable volume of radio can overcome it (not that it would be a real solution anyway).
I wanted to ask if someone has an idea how to find what seal/part is source of the trouble before I start a shopping spree for any and all rubber seals money can buy.
