I was in an accident recently. Tboned by a minivan at an intersection. Totaled my nice bike.
My buddy gave me an old rust bucket he had laying around just to get me to work for a few weeks until I get something else.
It's a Honda 600cc, early 90s. Carbureted. I replaced the battery but it's not holding a charge. It's backfiring all the time. And it accelerates insanely slowly, and pretty much sounds like it's going to fall apart if you give it the evil eye.
I'm going to replace the chain this weekend and take it apart to see where I can give it some love without really dumping any money into it.
Tips? Not sure what to do about the backfire or battery issues.
7
  • Does opening the choke reduce the backfire?
    – Zaid
    Sep 26, 2015 at 3:27
  • Is this a multi-cylinder bike with one carb per cylinder? Sep 26, 2015 at 11:00
  • Haha - I realized you threw "ancient" and "early 90's" into the mix ... I'm from the mid-60's ... what does that make me ;-) Sep 26, 2015 at 16:25
  • I thought the same thing when I wrote it.. but as it compares to sports bikes, it just feels ancient. First time I've ever ridden a carburated bike that I had to switch the fuel line on and off every time. I suspect the rust is crucial to keeping the whole thing in 1 piece at this point. ;) Sep 28, 2015 at 7:03
  • Trust me switching on fuel line on a carb bike is the least thing you could be worried about. Thank your gods that the jets are fine.
    – Shobin P
    Sep 28, 2015 at 8:31
For you backfire check the following components.
  • Clean Spak plugs
  • Clean carb
  • Clean air filter
  • If the other two dont work then there might be issue with valve seating, not 100% sure but there are chances since its old vehicle.
For your battery issue.
  • Check check the alternator/rectifier
  • The battery is new (just replaced)
    – Zaid
    Sep 26, 2015 at 3:03
