Is there a good way to change a pressed wheel bearing without a hydraulic press?
Clearly it's better to do it the right way, which I'm doing (well, a mechanic is doing), but I was wondering if a viable alternative would be pressing the bearing in using a C clamp or something.
I found this video of a guy freezing the bearing and heating up the hub then just sliding the bearing in, but that seems like it would compromise the integrity of one or both of those parts.
