We just bought a 99 Jetta - Working on the bugs.
  • With the emergency brake OFF, once I exceed 15 mph I hear 3 tones and the "brake" light starts flashing. Am I right to think it may be from an emerg. brake off switch not functioning? Where would I gain access to the switch to check it?
Any other suggestions?
Michael
The switch is usually somewhere under or behind the lever - you'll have to remove the trim around the lever to get to it. It'll be operated by a 'tab' on the lever itself.
However, on most cars I have dealt with, the 'brake' light will stay on constantly when the e-brake is engaged - so if the switch had failed, it would continue to remain on.
Have you checked the service brake for any issues? It might be detecting an imbalance between the circuits or similar?
| improve this answer | |
