10
I bought a used Skoda Fabia that is fitted with a parking assistant (reverse parking sensors) which does not seem to work.
According to the manual when I change into reverse it should either make a short beep (for everything alright) or a long beep (for "parking assistant not working"). Instead it makes no sound at all and the sensors also don't make a sound when there is an obstacle.
I checked the fuse (5er fuse in slot 9), but it looks ok from what I can tell.
Is there something else I can do myself before hitting up a repair shop? This is my first car and I have no knowledge about car mechanics, but am not afraid to learn and get my hands dirty.
The car was checked shortly before I bought it but they found no problem. According to the family member I bought it from the parking assistant worked before that.
UPDATE: As suggested, I checked if my rear driving lights work when I am in reverse. At least one side (back right) lights up, not sure if it should be two lights or if that's just normal?
UPDATE2: I finally checked some weeks ago. Doesn't seems to be the fuse. The multimeter showed power on both sides and the AC is wired on the same fuse and works.
8
    Does the reverse light work when you shift into reverse?
    – ozg
    Sep 10, 2015 at 9:34
  • I'm not sure, will check tonight.
    – magnattic
    Sep 10, 2015 at 10:49
  • Welcome to Mechanics.SE! Glad to see you over from Movies.SE :D I was wondering if it might have been turned off, but realize now that it sounds like it was working when you got it (or at least that is the indication). If you have a multimeter, you might check that the fuse is getting power on both sides with the ignition on (car may need to be running). Sep 10, 2015 at 22:18
  • @özg Check my update in the question. Any ideas?
    – magnattic
    Sep 12, 2015 at 3:00
    @Paulster2 I finally checked some weeks ago. Doesn't seems to be the fuse. The multimeter showed power on both sides and the AC is wired on the same fuse and works.
    – magnattic
    Jan 6, 2016 at 23:13
I had very similar symptoms on a BMW, the sensor itself was faulty and the problem was solved by replacing it.
There are two ways of diagnosing this that I can think of:
  1. Look at the sensor readings in the live data section of a diagnostics tool
  2. If you don't have access to such a tool, buy one new sensor and fit it to each position one by one until the problem is resolved
