1991 Nissan Sentra XE, 1.6L engine, 5-speed manual trans, 78k miles.
I unexpectedly had to stop driving this Sentra and it's been sitting unstarted in my garage for the past 6-years. It ran great, no apparent problems, very low mileage.
It's been a great car and now that I can drive it again, I want to "recommission" it correctly.
Advice varies--some say you must drain+replace all fluids; some say replace only gas and coolant; some say replace gas only if it smells bad and has turned to varnish; some say to only drop a little oil in the cylinders before starting.
So this non-expert is confused. What is the minimum required to safely re-start this Sentra? I have a new battery; I'd like to re-start car and drive to repair shop for inspection. How can I do this without harming the car?
Thx for info--
