I am wondering if the choke may be part of the reason I am having trouble with my mower. It appears that there is very little force causing it to stay open or closed. I am wondering if there is a spring that should be holding it one way or another, or if is vacuum operated. What could be the mechanism for actuating this thing?
Does your small engine have a primer bulb? – Pᴀᴜʟsᴛᴇʀ2♦ Sep 7 '15 at 21:15
There is typically a spring attached to the choke. Look online for a manual or parts diagram. A google image search might help also. – rpmerf Sep 8 '15 at 13:22
Can you provide the make/model/year of your mower? – DucatiKiller Dec 22 '15 at 18:32
