Engine A Specifications:
  • Displacement: 1198 CC
  • Max Power (bhp @ rpm): 87 @ 6000
  • Max Torque (Nm @ rpm): 110 @ 4800
Engine B Specifications:
  • Displacement: 1197 CC
  • Max Power (bhp @ rpm): 82 @ 6000
  • Max Torque (Nm @ rpm): 115 @ 4000
A brief explanation to answer will be much helpful!
  • Powerful how? Power to get off the line when the light hits green with relatively low RPMs? Peaks of power in high RPMs during a straight line drag race? Power in mid RPMs for your typical aggressive daily driver? Power coming out of turns in an odd gear? Power up a hill with a small trailer attached? Your question is like "What's the best fruit?" with no other information. Commented Aug 29, 2015 at 19:56
  • @ZachMierzejewski - You are mixing power and torque. IOW, you are mixing apples and oranges. Take the question at face value of "which engine is more powerful" ... taking the root of "powerful" to be "power", which would equate to horsepower, not torque. Commented Aug 30, 2015 at 15:49
  • @Paulster2 You're right I was mixing those terms. I read it as Aaron knows enough to know that the spec listed Max Power isn't the full picture, hence why he asked this and listed the torque spec. I understood powerful to mean "how the driver feels acceleration." Commented Aug 30, 2015 at 17:40
Engine A has a higher peak power
Namely 87 bhp vs 80 bhp. Both figures are achieved at 6000 RPM.
But a car doesn't always run at 6000 RPM, so it may be that Engine B has better acceleration as the engine goes through the rev range.
-1
To exactly address your Question it is Engine A as zaid suggests.
Hoping to give clarity on the engines themselves.
Engine A:
  • This has a better power than engine B , you will find this engine better for in gear acceleration and overtaking manuevers also this engine will allow a higher top speed.
Engine B:
  • This engine has better torque than engine A, you will find this engine better for city driving purposes since at slow speeds/RPMs its the Torque which is more prominent than the BHP. This engine will also have better fuel economy compared to engine A
  • Theoretically, it is true that engine A will allow a higher top speed. However, there isn't enough information to judge which engine will have better in-gear acceleration or which has a better torque characteristic. Also, fuel economy will be impacted by gearing more than the engine itself.
    – Zaid
    Commented Aug 29, 2015 at 20:16
  • I am considering all other factors to be similar for both engines/cars like gearing..
    – Shobin P
    Commented Aug 29, 2015 at 20:19
  • Even with that assumption, how can you be sure of which engine has the better torque characteristic? The max. torque figures are at different RPM's which makes it hard to compare them apple-to-apple. You really need a few more data points to be able to estimate what the torque curves look like. Two data points alone won't cut it.
    – Zaid
    Commented Aug 29, 2015 at 20:22
  • Well yes... It is difficult to pin point the exact figures with the provided information but I was not trying to give it in the first place..
    – Shobin P
    Commented Aug 29, 2015 at 20:24
