When talking about a 2014 Jeep Cherokee, what is the difference between CAN-C and CAN-IHS buses?
    There are two PDF's which will probably help you tremendously here. Since you specify the 2014 Jeep Cherokee and wondering about the CAN-Bus, I'm assuming you are wondering about the hack which was done by Chris Valasek and Charlie Miller. I found their white papers which spells a lot of this out. You can find them here and here. The first one contains a bit of the info of the second, but you'll see the difference. Aug 26, 2015 at 20:33
8
CAN-C is the high speed bus that connects the engine, brakes, airbags etc. CAN-IHS is a low speed bus that connects the comfort systems like radio and climate controls.
  • I though HS stands for High Speed...
    – user11642
    Sep 4, 2015 at 6:05
