How do you remove engine cooling fan from A-Class Mercedes W169?
  • I love the straightforwardness and simplicity of this question, awesome :)
    – Dan
    Commented Aug 6, 2015 at 13:42
  • This should help: youtube.com/watch?v=WAk1iD13iBg
    – Dan
    Commented Aug 6, 2015 at 13:49
  • There is an umpteem number of achieving that. Nevertheless, if you want to use the fan and/or the engine we could use more details.
    – aldux
    Commented Aug 6, 2015 at 16:25
  • How does the cowling and engine cooling fan come out of the dngine compartment Commented Aug 6, 2015 at 19:35
  • Looking at it i think i might need explosives to get it out it seems very tight many thanks to anyone that can help Commented Aug 6, 2015 at 19:39
unplug the fan connector and make sure every thing is cold then twist the fan clockwise it should be lose from its main frame of the radiator then try easily to get it out without touching the oil tubes of the AC as force can damage the tube and it will cost you he patient as its too narrow hood and you will find it difficult to remove it if you have big hands
another solution for big hands get under the hood and remove the protective plate do the same and you have to get it from the hood not from down
