When I turn my keys and all lights are on but when I try to turn the car on nothing happens. Would it be that my starter is bad and need a new replace? Any help?
  • Which vehicle is this? Year/make/model?
    – Zaid
    Aug 1, 2015 at 2:04
  • 96 acura integra gsr
    – user11584
    Aug 1, 2015 at 12:49
  • On my particular truck this means replace battery as there's not enough voltage to crank the starter anymore.
    – Joshua
    Apr 18, 2017 at 14:42
A bad starter is just one possibility
Generic culprits for no-cranking include:
  • bad starter
  • bad starter relay
    If you don't hear a "click" when you try to start the engine this is may be worth checking
  • faulty ignition switch
    If the relay doesn't click when the key is turned, but clicks when 12 V is applied to it externally, the switch might be to blame
Recommendation
Consider replacing the starter after eliminating the other possibilities.
