NOTE: Much of your question seems to be a rant, so I will answer the last part, which seems to have gone unanswered to this point.
According to the Battery University, a typical lead acid battery will lose about 5% of its charge every month (whether this means 5% of of the total charge when completely full - ie: 5%, 10%, 15%, etc, or 5% of the remaining charge - ie: 5% of 100%, 5% of 95%, 5% of 90.25%, etc, is unclear). This means if a battery sits on the shelf too long, it will need recharged after a period of time to be fully operable in a vehicle.
That is for a battery which is stored wet (with acid in the cells). A dry battery (one without an electrolyte) will maintain on the shelf indefinitely. Once the electrolyte is placed in the cells, the process begins.
There is another factor which will make a battery go bad. According to the same website:
With usage and age, however, the flooded lead acid builds up sludge in the sediment trap, which causes a soft short when this semi-conductive substance reaches the plates.
This can cause issues when the battery gets old. I assume it happens at a slower rate while on the shelf, but will still happen over time as it becomes aged.
What this means is, a battery with acid in the cells can only sit on the shelf for so long before it must be recycled or it will not work right. Have no fear, though, lead from batteries is one of the most recycled things we humans pull out of the ground. A battery which has sat on the shelf for too long, while it may not provide you good usage, will still be able to be exchanged for a new one under the normal battery warranty programs. I'm sure batteries are sold beyond their expiration dates, but they are also easily replaced.
