14
When trying to diagnose problems with conventional analogue electrical circuits, such as lights, speakers, heated rear windows, etc, as well as short-circuits and unexplained current draws, it can be difficult to track down the exact source of the problem. What is the best way of doing so?
8
Tools
  • Digital Multimiter
    • Voltage, Resistance, continuity settings
    • Automotive specific DMM's are typically the same device but may have a few extra features (Duty Cycle, RPM)
    • CAUTION: Certain modes on the multimeter can cause damage to the device or your car if improperly hooked up. Never connect the DMM to a circuit in parallel when it is on the ampere setting (take caution when changing setting with probes attached), never use continuity testing on a live circuit unless the device specifically is ok with it. Do not measure Resistance on a live circuit. some tests will require you to have battery on and others will require you to disconnect the battery
  • Test Leads and Test Jigs
    • Minimum set includes basic contact probes (comes with DMM) and Aligator Clips. First thing to get is 20 ft banana plug extension to extend your probes
    • A set of automotive connectors with test leads for easy probing would be the next thing to acquire.
Additional Tools that you May Want:
  • OBDII Reader for pulling codes and getting gross sensor data
  • CAN sniffer for low level communications testing
  • Oscilloscope for thoroughly verifying electrical signals
  • Soldering iron to make electrical jigs
For all testing, make sure to find, print, and understand the wiring diagram for your car, it will make your life much easier if you can use the diagram to determine the expected connections, voltages, and signals at any node where to find them
Testing
Automotive electrics for Conventional (non hybrid combustion) cars can be broken down roughly into three domains
  1. Power Components: Charger, Alternator, Starter, "Power Circuit"
  2. Analog Components: lights, relays, fuses, low current power
  3. Computer Components: ECU's and advanced sensors
The difference between Category 1 and 2 is that 1 is before the fuse box (directly to battery with fewer protective elements) and 2 is generally fused circuits. Greater precautions need to be taken to avoid crowbarring the battery, whereas a fuse will protect you from mistakes. Category 3 will require some additional or specialty tools. However, elements of category 3 will have some overlap with 2, you can verify some very basic functionality without busting out a sniffer (test power supply to components, shorts and breaks)
Power/Analog Components
Here everything is about long and convoluted harnesses, fuses, relays.
With the wiring diagram in hand the First stop is to identify the relays and fuses that are controlling or protecting the circuit believed to be at fault. Verify Continuity between connected nodes (e.g. if the fuse for the headlights connects directly to relay, verify - with the battery disconnected - that there is continuity between the fuse panel and relay panel). Verify/replace fuses and relays. Continuity check everything you can to eliminate harness/wiring damage.
After a basic continuity check we can move on to signal verification tests. With the battery connected you can test voltages at key points on the circuit. Relays that are supposed to be on will have 9-12V on the control pin, verify power at the fuse panel by removing fuses and checking the voltages on related pins. Where you expect a voltage make sure you are reading a voltage. You can compare the voltages on every pin of a relay socket with relay installed and relay removed (this is where connector jigs come in handy) , this will help you further narrow the problem search. You can use the wiring diagram to unambiguously determine which circuits should be on/powered with given switch/key positions. Any signal pins that go to the ECU (related to the faulty circuit) should be noted and tested later.
Functional tests can be performed on most components. Using a 12V supply that is not the car battery you can check relays, pneumatics/valves, lights, fans. etc. by connecting the supply across the relevant pins. Lights will turn on, pneumatics will tick, relays will tock, fans will spin, and pumps will whir.
Computer Components
Verifying ECU and sensor functionality can range from easy to complicated. The most basic check you can do is to verify that the power supply lines to these devices have the required voltage (can typically be done right at the connector) and verifying the relevant fuses and relays supplying power to that circuit.
If the supply is present then you can dive down the rabbit hole of troubleshooting sensors and computer electronics. The first step is to verify that the device is functioning, this will require looking up the part number determining the signal the device supplies to the ECU. Analog signals can be read using a DMM, digital signals will require a sniffer or oscilloscope. You can also test with a known-good device.
If the sensor appears to be functioning but the relevant system is malfunctioning the best bet is to take a CAN sniffer (the majority of intelligent sensing elements send their data to the ECU with a shared bus called CAN) and capture the communications data. It may be difficult to interpret the communications, but in general I would suspect the following . no signal - Broken connection, dead/damaged device or ecu. gibberish data (Look at the data sheet for the device to see how it formats data)- Damaged device, digital noise/damaged wiring , corrupt ECU.
|improve this answer|||||
  • Excellent Answer :) Could you split out the stuff about the computer components into a separate question-and-answer? I was trying to keep this question to just conventional, analogue circuits for clarity - I've added the word analogue to the question to clarify that... – Nick C Jul 15 '15 at 9:34
  • Indeed, great answer. – DucatiKiller Feb 10 '16 at 7:34
8
To track down and troubleshoot electrical issues, you will almost certainly need a multimeter (also known as a Volt-Ohm meter) - digital ones are best, like the one illustrated below (from Wikipedia)
Fluke Multimeter, courtesy of Wikipedia
You can get cheap ones, which are fine for most automotive stuff, or much more expensive ones with all sorts of clever features.
The two most useful things for car work are the DC voltage setting (The V with solid and broken lines above, at 10 o'clock on the above picture), and the continuity tester setting (the sound-wave and ohm symbol at 12 o'clock)
Testing for voltage
To check whether a circuit has failed, one of the easiest ways is to see if 12v appears when it is turned on. I'll use the simplest example of a light that isn't working. Set the meter to DC Voltage, and switch it on. Remove the bulb, and switch on the circuit. Hold the red lead on the meter to the contact in the bulb holder. At the same time, hold the black lead to a clean, metal part of the car (for example, the engine block) - a 'ground'. If the circuit is working, you should see '12' (or something near, e.g. 11.9 or 12.1) on the display.
You can demonstrate this easily by touching the red lead to the battery terminal, and again touching black to ground - you should see between 13.5 and 14 volts for a normal, healthy battery. Alternatively, for a safer demonstration, touch the leads to either end of a domestic 'AA' type cell - this should read around 1.5V
Testing for continuity
If you know a circuit has failed somewhere, you then need to work out where. You have two options for this - either keep working back along the circuit with the meter as above, or test each section for continuity (or, more usually, both).
To test for continuity, set the meter in continuity mode, and touch the leads together - you should hear a beeping or buzzing, and see a low number on the screen (e.g. 0.0001) - this means there is a low resistance between the leads. Separate the leads again, and the buzzing will stop and the screen will usually show '1' on the left hand side - this means there is no connection between the leads. Hold the leads either end of the part you want to test (e.g. to the two terminals of a bulb) - if the circuit is complete, it will buzz.
Common Faults
There are certain failures that commonly occur with automotive circuits...
  • Earth faults - Probably the most common, and often intermittent. Most circuits earth (ground) through the bodyshell of the car, and the points where they join can corrode, resulting in a poor connection. These can be checked by using the meter in continuity mode, between the earth side of the component and a clean part of the bodyshell.
  • Internal faults - for example, bulb holders no longer making good contact with the bulb.
  • Switch failure - Switches can fail internally, causing contact to become intermittent, or fail completely.
  • Relay Failure - As with switches, these can fail internally
Broken wires are rarer, but not unknown, especially with circuits that pass through the doors, such as electric windows, central locking and power mirrors, as the wires passing into the doors are flexed every time the door is opened, and can fatigue and fail.
Of course, a lot of modern cars also have loads of ICs, buses and computers controlling everything, but they're a subject for a different question...
More on using a Multimeter
Sparkfun have a guide on using meters, with loads of pictures:
Guide!
Aimed at hobbyist electrical stuff, but the principles are the same here...
    What a superb answer, I really enjoyed reading that. – Dan Jul 13 '15 at 14:30
    You would show the best & possibly the most expensive multi-meter (brand wise) on the market! Great read, BTW! – Pᴀᴜʟsᴛᴇʀ2 Jul 15 '15 at 1:47
  • Haha, that was just the one that Wikipedia had a suitable photo of. My mid-range generic brand one does just as much, and probably cost about a third of the price of a Fluke one... – Nick C Jul 15 '15 at 9:30
  • You mind if u use this for the multimeter tag-wiki? – DucatiKiller Feb 10 '16 at 3:37
  • @DucatiKiller go ahead! – Nick C Feb 10 '16 at 9:17
I'd like to add to Nick's answer and mention a Circuit Tester if you need to simply test the circuit for power.
https://www.reddit.com/user/waynep712222
Created by Reddit User Waynep712222
Adding to the accepted answer: A good tool for tracing unexplained current draw would be a current clamp, suited for DC measurements in the milliampere range
