If I compression test my engine and the results are fine, could there ever be any need to leak-down test it as well? IOW, can a leak down test ever fail if the compression test is fine.
RELATED: Cylinder Leak-down vs Compression Test
Yes it can. The reason is, these are two different tests, done differently, reading different things. To understand this, you need to understand how the tool works for each test.
For the compression test, the test apparatus captures and holds the compression as it builds through several, but counted revolutions of the crankshaft. You will get so much pressure built up on the first revolution, but this will not be the complete pressure. You need to turn the engine over for four or more compression cycles on that cylinder in order to get your reading. It is important you run the compression stroke the same amount of revolutions for each cylinder to get an accurate reading between cylinders. There are two main purposes of the compression test: 1) to get a final compression pressure reading; 2) to see the variance between the cylinders after all cylinders are tested.
For the leak down test, a separate air source is used. You put the apparatus into the spark plug hole, ensure the piston is at top dead center (TDC) of the compression stroke (to ensure all valves are closed), then apply the air to cylinder. You then take the reading and see what your leak down % is. (Here is a good video of the procedure) Again, you are looking for overall leakage as well as the difference between cylinders.
The major difference here is, even if you have a cylinder which has a leaking valve, it will still continue to build pressure. The pressure may be less than it should be using a compression tester, but you'll still build pressure because the gauge itself will capture the pressure as it builds.
  • Doesn't answer the op question. – John Moore Oct 6 '17 at 21:13
No, not needed. A compression test is like a general check-up with your doctor. Check the basics and look for abnormalities.
A leak-off test is a specialist test to find the cause of the abnormality. If you find a cylinder with low compression, a leak-off test will tell you why. If air leaks out of the exhaust or intake manifold, a valve is leaking - cylinder head repair required. If it leaks out of the oil cap/PCV system, rings are allowing excessive blow-by.
A leak-off test also has a gauge to measure how much pressure is being maintained. If you are familiar with your tool you can determine how severe the leak is.
A leak-off test alone is not useful as the pressure applied does not fully seat the piston rings. Proper ring sealing is not achieved without normal compression pressure.
Not the answer you're looking for?Browse other questions tagged or ask your own question.
