I would like to know what happens when the disc brake lever is deeply pressed when wheel is removed.
Does it cause any damage? If yes then what should be the repair and how much it may cost?
Update: It is a motor bike. The wheel is placed back in place. The problem now is the disc pads are brushing against the rotor causing more friction and restricting the free wheel motion. What could be the possible reason for this behavior. Is there any chance of air getting into the braking system?
