20
I'm struggling to find information on how engine load is defined. Is it really just a fancy word for torque demand?
There are three parts to this question:
  1. Is there a theoretical equation that is used to define engine load? If so, what is it? I couldn't find anything definitive in the Bosch Automotive Handbook.
  2. What parameters does an ECU look at to sense and determine the engine load? I don't think there is a single tell-all sensor which returns the engine load; there are likely several signals being combined here.
  3. Some ECU's appear to make a distinction between relative and absolute engine load. What is the difference between the two?
  • what is that book (Bosch Automotive Handbook) like ? is it good as a reference manual for a backyard mechanic ?
    – amphibient
    Commented Jun 10, 2015 at 15:49
    @amphibient : It's a handy reference for automotive design/state-of-the-art. It's catered more towards engineers than a DIY-er but I wouldn't recommend against having a copy on hand :)
    – Zaid
    Commented Jun 10, 2015 at 16:34
  • It's worth noting that there is a layman's usage for "Engine Load" for vehicles without an MAF sensor. That is simply the ratio of throttle position sensor to RPM. This is regularly referenced on motorcycles as they rarely have an MAF sensor.
    – justinm410
    Commented Sep 7, 2016 at 14:37
22
It's not theoretical, but real. According to SAE International SAE J1979 / ISO 15031-5 (dated: 2014-08-11), calculated engine load is calculated by the following equation:
LOAD_PCT = [current airflow] / [(peak airflow at WOT@STP as a function of rpm) *
     (BARO/29.92) * SQRT(298/(AAT+273))]
Where:
- STP = Standard Temperature and Pressure = 25 °C, 29.92 in Hg BARO,
- SQRT = square root
- WOT = wide open throttle
- AAT = Ambient Air Temperature (in °C)
Characteristics of LOAD_PCT are:
- Reaches 1.0 at WOT at any altitude, temperature or rpm for both naturally
  aspirated and boosted engines.
- Indicates percent of peak available torque.
- Linearly correlated with engine vacuum
- Often used to schedule power enrichment.
- Compression ignition engines (diesels) shall support this PID using fuel
  flow in place of airflow for the above calculations.
The second part of this portion (Characteristics) gives you a lot of the information you are seeking. The percentage given by the equation indicates percent of peak available torque.
There isn't a single sensor it uses to figure this out. For a gasoline (or spark ignition) engine, it utilizes the Air Intake Sensor (IAT), Manifold Absolute Pressure (MAP) sensor, Throttle Position Sensor (TPS), and Engine Coolant Temperature (ECT) sensor to do calculations and to discover if the engine is at the ready point to make the calculations. The percentage variable can be read from the ECU using PID $04. According the the standard, both compression ignition (diesel) and spark ignition (gasoline) systems are required to maintain this.
You've seen the above equation for calculated engine load. Below is the calculation for absolute engine load:
LOAD_ABS = [air mass (g / intake stroke)] / [1.184 (g / intake stroke) *
     cylinder displacement in liters]
Derivation:
- air mass (g / intake stroke) = [total engine air mass (g/sec)] /
    [rpm (revs/min)* (1 min / 60 sec) * (1/2 # of cylinders (strokes / rev)]
- LOAD_ABS = [air mass (g)/intake stroke] / [maximum air mass (g)/intake
    stroke at WOT@STP at 100% volumetric efficiency] * 100%.
Where:
- STP = Standard Temperature and Pressure = 25 °C, 29.92 in Hg (101.3 kPa)
  BARO
The quantity (maximum air mass (g)/intake stroke at WOT@STP at 100%
volumetric efficiency) is a constant for a given cylinder swept volume.
The constant is 1.184 (g/liter 3) * cylinder displacement (liter 3/intake
stroke) based on air density at STP.
Characteristics of LOAD_ABS are:
- Ranges from 0 to approximately 0.95 for naturally aspirated engines,
  0 – 4 for boosted engines
- Linearly correlated with engine indicated and brake torque,
- Often used to schedule spark and EGR rates,
- Peak value of LOAD_ABS correlates with volumetric efficiency at WOT.
- Indicates the pumping efficiency of the engine for diagnostic purposes.
As you can probably see, this equation relies on the flow of air and basically engine displacement. As it states in the body, this correlates with volumetric efficiency (how completely a cylinder fills with air on the intake stroke) at WOT. This variable can be read from the ECU on PID $43. It is only required by the standard on spark ignition systems.
    great writeup. what i would like to know what sensing mechanism(s) the engine (or ECU) uses to determine input factors based on which the torque demand is determined. IOW, if the vehicle is going uphill or is towing a heavy weight, the torque demand is bigger. how are those demands gauged ?
    – amphibient
    Commented Jun 10, 2015 at 15:58
  • @amphibient - I'm sure throttle position, mass air flow, and rpms are the big ones. As you are going up hill you have a certain amount of rpm to maintain a speed. In order to maintain that speed, you'll need more throttle, which will allow more air to flow through. More air flow at a lower rpm will indicate a higher torque demand. This is a SWAG on my part, but believe it to be an educated one. Commented Nov 4, 2015 at 23:04
  • Hi, this is a great answer. I am trying to determine if the engine is reaching stall. Can the engine load be used to determine this? Commented Dec 20, 2015 at 13:00
  • @MohammedLokhandwala - Please ask this as its own question and refer back to this answer if it helps explain what you are trying to ask. Commented Dec 20, 2015 at 13:04
  • Why would LOAD_PCT use the MAP sensor and not the MAF? My 98 626 doesn't even have a MAP sensor, yet the ECU supplies a "Calculated Load" PID. Commented Jun 6, 2016 at 8:55
Engine load is measured by the MAF sensor. In other words, it measures how much air (and fuel) you're sucking into the engine and then compares that value to the theoretical maximum. When I modified my Subaru's fueling, boost and ignition maps, all the tables plotting engine load to RPM referenced engine load in CFM (Cubic feet per minute). It basically means that because my turbo flows e.g. 350cfm max, the closer the actual airflow is to that, the higher the load percentage.
